Roller Shutter 4 – Missing Parameter 153 (Restore Slats to Previous Position)?
Hi everyone,
I’ve recently installed seven Roller Shutter 4 devices in my home and noticed that, unlike the Roller Shutter 3, parameter 153 seems to be missing. This parameter allowed the slats to return to their previous tilt position after opening or closing.
Is there any way to achieve the same functionality with the RS4? Maybe through another parameter or a workaround?
This feature was quite useful for me, so any advice or insight would be greatly appreciated!
  • 3 weeks later...
Hi, I am facing the same problem so I've changed motor connections and switches. Most of the times it works alright and if not you don't mind if the blinds turn a bit when they are not open.  But in the future would be nice that Fibaro could add parametr 153 or whatever to fix it.
  • 4 months later...
is there anyone who has found a solution? I am experiencing the same issue.
