Good morning,
as I know a scene can be started on HC3 by:
https://user:passwd@hc3_num/api/scenes/scene_number/execute
Is it possible to invoke a function of particular quickapp similar way - via http(s)?
or start a quickapp from the begin (onInit)?
You can also send arguments.
In hc3emu, request to hc3emu will redirect the call to the emulator api, for testing...
Another sample you can find here:
Yes,
but the GET request allows you to put the credentials in the URL. (That's why I think Fibaro kept it around even if they have a POST version starting with HC3)
The POST you need to add the credentials in the headers as "Authorization: Bearer..."
Som devices only allow you to use GET for web hooks.
More "modern" devices allow you to setup a post request with custom headers and even payload.
