Chrisash135 0
Hi, I have been using Fibaro HC2 for four years along with eyeball control of heating zones at home, but these were set up by previous owners. We have three underfloor heating zones, each one linked to a specific eyeball temperature readout and controlled by the heating panel for those zones. Today one eyeball started giving really high temperature readings, I removed it from the system then added it back. It then started giving correct readings. However it doesn't now appear to be linked to the underfloor heating switch in that zone any more, so the panel settings or manual operation on the panel doesn't switch the heating on. It is as though the devices (eyeball-panel-underfloor heat switch) aren't connected any more. How do I connect them? I have tried to see of I can learn from one of the other zones to see how they are linked, but don't know where to look. Help appreciated
