it is not recognized by HC3.
Another "variant" different than previous ones, we already got 14 definitions for this device - almost like with Marvel last years ;)
With Zigbee its like that, it never stops...
    any chance to create the 15th? :D
    update:
    I was able to connect the sensor as soon as I've put it closer to HC3 hub. The question is now - HC3 sees the sensor as normal PIR, no "human presence" state, just on/off, missing any controls... do you plan to change and enhance it so it works same as in ZigBee gateway?
    Edited by jcichon01
    So definition is there, thats good.
    As for support, there are no plans to change the presenation - you can change the role to "Presence sensor" which will change the icon, but still - it will be a binary sensor only.
    Any plans on expose more off the zigbee massages in the api/events? 🤔
    Then we could have created QA ourself to get zigbee devices working 😅
    and a way of sending spesefic messages to the zigbee devices?
    We were thinking about it in the past, to allow communication directly with specific addresses but it is not so simple to do.
    I will get back to that one and see if this can be done or not.
