After upgrade to 5.180 I can no longer save changes in the morning scenario. No matter what I change (start time, days of week, selected blinds) the Save button remains inactive. This happens both through web UI and Yubii mobile app. Navigating away from scenario edit shows popup that unsaved changes will be lost, but the 'Save and continue' button is disabled in this popup as well.
I tried to create a new scenario from scratch, but the results are the same - Save button is disabled preventing any configuration for the newly created scenario.
I regularly need to update the start hour of the scenario and now I am unable to do that, please assist.
Hi raspy, can you post a screen shot of your scene? Maybe no trigger has been defined in the conditions block …
Edited by awlieser
    Note that Save button ('Zapisz') is inactive, even though the changes have been made (start time to be exact).
    Did you try a standard (block) scene and see what happens …
    Edited by awlieser
    Standard block scenes work and can be edited. Scenarios also work, they just cannot be saved. Please get it fixed in some near update.
    Same problem here - returning to version 5.171.15 (beta) made scenarios editable again on Yubii Home
    Edited by Andergast
    • 3 weeks later...
    I have the same problem. Tried to uncheck a device in the scenario and it will not allow me to save
    @Andergast Did anything get messed up when you reverted to the older version?
    I do not know how to even revert back to the old version. Any guidance would be much appreciated.
    Edited by Nanis
    • 3 months later...
    Good morning
    I have the same problem even after last update 5.190
    Any news ?
    • 1 month later...
    This is still not fixed. However, I noticed that this seems to be a (potentially) simple error in the UI.
    If you happen to have multiple blinds in the room and you uncheck one of them (so that in any room not all blinds are selected) the Save button gets enabled. This of course may not be what you want (to have one blind excluded), but it shows that it's not something fundamental. Therefore what I do now is: set the scenario as I want it to run and if the Save button is disabled, I start development tools in my browser (F12), use the DOM inspector to find the button (footerSaveButton), click on the HTML code in the inspector and remove the disabled attribute. The button gets enabled, can be pressed and it saves the scene correctly.
    Now, given that it looks like a simple logic error on the page, it should not be that hard for the development team to fix ;-)
    Guys anyone has a solution for this?
    Scenarios are not editable..I can only delete them.
