Hi all,
I saw some posts regarding this but no real solution, wondering if anyone has solved this yet.
Have some Dali controlled lights (momentary switch - single press = on/off, long press = dim up/down) and wondering how to make this compatible with Fibaro/ZWave. I did see there is a Zwave to Dali controller although hard to find a place to buy (in Australia). Wondering if there's other solutions?
Appreciate the help guys!
Check out eulink with a dali module, it is a Dali gateway.
@NickBusselmann, If you can, try to ask Fibaro/Nice Australia distributor for this device:
. It can do DT-6, which is Single channel (no rgb) lights.
    thanks guys, I did see that Zwave to Dali controller online but doesn't appear to be available in Australia.
    I was wondering if anyone had figured out a 'hack' to make it work with fibaro modules.
