How to format the date time from-to string for energy consumption
I used swagger to get info on the lua command to read energy usage over a specific period of time for a device but i think some info is missing there.
A single date works fine: 'http://x.x.x.x/api/energy/consumption/device/36/detail?periods=2025-06-01'
Two strings works also fine but that returns not a energy usage over a specific period, it returns two values: periods=2025-06-01,2025-06-20
This does not work:
periods=2025050120250620
periods=20250501-20250620
periods=2025-06-01%2F2025-06-20
periods=2025-06-01-2025-06-20
What is the right formatting for a start date and end date?
Hi @Casa Domotica,
I use following code to get energy consumption for my solar panels from QA that shows current export power:
What you get as an answer from HC3 is actually table of values:
BTW - there is no such call explained in Swagger. I get it here from forum. Hope this helps
