After updating from the HC3 Ver. 5.170 to 5.180, it appears the support introduced in Ver. 5.170 for the Zipato Mini Keypad for z-wave engine 3.0 did not carry over to the 5.180 update.
The binary switch portion works, and user/RfID codes can be programmed in 5.180, but the profile change ability has disappeared, and the lock does not change the UI from unlocked to locked.
Is this one of the legacy devices that might be added back in in a future update, or has this device reached it's end?
we will check it out :)
    Looking into the device configuration, I see some items that may provide clues to the non-function of this device.
    1. There is no Lifeline association to group 1.
    2. "available DoorLockModes": [],
    3. "supportedDoorLockModes": [],
    I am guessing that since there are no available or supported modes, it isn't going to function as a com.fibaro.doorLock.
    Hope this helps to troubleshoot the issue.
    Thanks.
    • 3 weeks later...
    So, its was not related with any of those but I got confirmation that its fixed in upcoming 5.182 beta :)
    • 1 month later...
    Thanks for the update! I look forward to a reinstall after updating to 5.182.
