I'm Implementing a HC3 QuickApp for my AC. I already have a simple implementation for one AC device and it works fine. I use `com.fibaro.hvacSystemCool` type and some additional buttons for custom modes (I used a configurator in the HC to configure them). Now I want to extend it and get the configuration for all devices and create them automatically as a child devices. I have a basic solution in place but I'm fighting with adding a custom view (additional buttons) to the child device. How I can achieve that?
I already exported a UI JSON from my first solution but I can't find where I should put it.
    Ok, I found the solution.
    In the createChildDevice function you need to add uiView property with the code generated by 'Copy JSON view button'
    And then you will see the custom UI elements, but the actions for the buttons won't work. What I've done (based on other posts on this forum) I've added QuickApp:UIHandler(ev) function to the main app:
    And uiCallbacks definitions to my Child app:
    • Like 3
    One more thing. Is there any way to update uiView of the child device when it's already created?
    You can "PUT" the new view anytime :)
