Don't see new backup-files after migration HC2
I migrated from HC2 to HC3 everything looks to work fine but I keep getting a message that there is a backup file for migration and I can't see or select anything in the backup area. I am able to create a new backup but I can't see it listed. I can't select the one that is listed.
If change from HC2 to HC3 you must start from scratch. You can fix it with a back up.
Hmm, strange - you should be able to migrate / restore your devices from your HC2 backup. Scenes/VDs won‘t work - they have to recreated/replaced by QuickApps. Just search the forum on advice to migrate from HC2 to HC3.
Indeed, you can transfer a configuration to another homecenter in the Yubii Remote
/monthly_2025_07/image.png.660a441e6a1353c92c6562bd1cfc3ac9.png" />
also see:
Same problem... look's like is ok,... but cannot create new backups, neider restore the old one (migration backup)
  • 6 months later...
Same problem here, have you found the solution?
  • 4 months later...
Hier ook het zelfde probleem.
Ik heb ook gemigreerd van hc2 naar hc3. Werkt allemaal, maar ik zie alleen hc2 backup staan.
Ik kan een cloud backup maken, maar hij verschijnt nergens. Lokaal staat er dat ik eerst een backup moet verwijderen om ruimte te maken. Maar ik zie nergens een lokale backup staan.
(@Patrickpizza better write in English, you probably get more response)
Edited by SmartHomeEddy
