Weather provider and weather condition codes mixup, Whaaaat???
Dear @m.roszak and other brothers in pain that are still using Fibaro gateways!
I have done some testing with my weather provider and weather condition codes just to find out how Fibaro managed to do complete nonsense out of this.
First of all this list of weather condition codes was still working on the last stable update 5.180:
at least most of them and above codes are almost same as they were on HC2.
Of course, on HC3 WeatherCondition description is reduced to this list:
  • clear
  • partlyCloudy
  • cloudy
  • storm
  • snow
  • rain
  • fog
BTW - in the QA example that mr. @m.roszak or mr. @A.Socha is usually asking you to download from
is still NOT corrected after so many years.
Since some genius in Fibaro development team changed so that WeatherCondition selects what weather icon will show on dashboard instead ConditionCode that example is now not so incorrect, now is just missing WeatherCondition "partlyCloudy". Of course this still will work only if you also set ConditionCode to one of available ones:
  • 4
  • 20
  • 30
  • 32
  • 38
  • 40
  • 3200
Of course, it doesn't matter if you put ConditionCode 40 which is for "rain", but then set WeatherCondition to "clear" because you will get icon for "clear" even ConditionCode is set to 40. Only ConditionCode 3200 for "unknown" will show icon with crossed circle for any WeatherCondition that is set.
I do not need to mention that after QA changes WeatherCondition from eg. "clear" to "rain" (no matter if ConditionCode is set to proper code or not), then dashboard or GUI home page must be refreshed at least in Firefox to show appropriate icon.
Since ConditionCode and WeatherCondition can be mixed and then WeatherCondition has higher priority next table is for info only and might be wrong:
Notice that weather conditions "cloudy" and "partlyCloudy" has same ConditionCode, but on dashboard show different icons :-P
So, now I ask Fibaro:
What is weather ConditionCode actually used for ??!?!
Have you really deleted all weather icons from above picture and left only few for the WeatherCondition list?
So, in general we will bring back the handling for conditionCodes from HC2 for now, we will clear this out and document this later this year. Those were not intended here but was still there for last years.
Probably we will just bring back some of the obsoleted condition codes and make new weatherCondition enums to support more options, document the backward compatibility.
    So, that means that I can put on hold updating my weather providers QA until the end of this year?
    That is not problem, since I have lots of other coding to do in the mean time, but I really hope you will give some at least basic documentation so I do not have again to loose valuable time to find out what is done through trial & error way as I had to do for the last 10 years. THANKS!
    So, for sure ultimately weatherCondition enum will be the one to use, we will document the change.
    webUI will go back to previosly used conditionCodes for now so that your current solution will be running the way it was before.
    • Thanks 2
    • 1 month later...
    Hi @m.roszak,
    any news on this one? Thanks!
    So, we reverted back the handling for conditionCodes in 5.183 beta.
    As for the improvements here, it will take some time to rewrite as this affects also the apps.
    Hi @m.roszak,
    Well doesn't look OK, even for YR Weather which is maybe abandoned but still new HC3 came with it installed:
    What is actually official alternative for YR weather anyway?
    Any idea how much time? A month, a year, next 5 years? ;-)
    Its just "clear" condition code, not all old codes has seperate icons now - we mapped some.
    For now we need to live with it.
    Hah, lets thing more like in Q1/Q2 2026 - not this year for sure.
    Its in the backlog.
