Rollershutter 3 missing venetian blinds setting
for my FGR-223 Roller shutter 3 on my HC2 running 4.630 version i am missing in web and yubii app the option to set the venetian blinds position  (attached screenshot position1)
the roller shutter has the parameter 151 set already to "2" Venetian blinds but this has no effect on the dispalying of buttons under device /slaves (attached screenshot position2)
Also some icons are missing for Roller shutter3 (attached screenshot icons)
RS3 firmware is up-to-date 5.1
I have tried reconfiguration, removing and adding again.
Also an another RS3 added to my HC2 behavious in same way
Is there a know problem with RS3 on HC2 running 4.630?
Other RS2 purchased many years ago running 5.1 are all fine and i can see the venetian blinds setup/buttons
Would installing RS2 firmware on RS3 help?
Or is there an other way, except buying ne RS2
Hi @sponch,
HC2 last update 4.630 was 3 years ago while FGR-223 came out 1 year later so it is very likely that HC2 is not entirely supporting this device.
    Does any one want to trade 2 roller shutter 3 FGR-223 for 2 older roller shutter 2 FGR-222? Send me a message
    Thanx
