I have a QA for connecting Fibaro and Solar Asisstant + Growatt.
I made a complete self-installing QA for loading data from Solar Assistant. Would anyone be interested in trying it out? I have a Growatt SPH 100000 inverter and the data retrieved looks like this.
Just set the IP address and port, If anyone wants to try it, I'll send the QA to the unit number. I will only provide QA to a limited number of people, as this is still a trial version. My main goal is to get feedback. Thank you for your understanding.
Edited by petro_cz
    Edited by petro_cz
    Thanks for sharing the file, petro_cz. I’ll give it a try and see how it works with my setup.
    Good morning Petro, I have a single-phase Deye inverter with Solar Assistant. I tried your QA and it works well in my HC3, but I can't change the time parameter, which is stuck at 60. Is it possible to also add Auxiliary PV to the parameters to be viewed?
    Hi
    • 4 weeks later...
    On 15. 8. 2025 at 8:27, Fabrizio1969 said:
    Dobré ráno, Petro, mám jednofázový střídač Deye se Solar Assistantem. Vyzkoušel jsem váš QA a v mém HC3 funguje dobře, ale nemohu změnit parametr času, který je zaseknutý na 60. Je možné k parametrům, které se mají zobrazit, přidat i pomocnou fotovoltaiku?
    Ahoj.
    Hi
    I have a Growatt inverter and the time is set here; I am unable to simulate a different inverter.
    • petro_cz changed the title to I have a QA for connecting Fibaro and Solar Asisstant + Growatt.
    I have a new version that installs subfolders automatically and is fully functional. I need to test it on more devices, so if you're interested, please let me know.
