Inclusion of a Shelly Wave Motion sensor - any success?
All, has anybody managed to inlude this sensor? Includion process started, but in the end failed. Device is identified as motion sensor, but marked as „Not configured“. 😕Thanks! Cheers Alfons
Edited by awlieser
8 answers to this question
I am not sure what could be the cause here, I don't see this device on Z-Wave alliance page as a certified one - probably something is not implemented according to Z-Wave specification here.
Send the logs dump from the system after inclusion, I will check the logs to check it out to give you some details what may be the cause here.
I think I encountered simmilar issue in the past with Shelly Wave 2PM. Try to set Association group 1 to Multichannel if it was set to Singlechannel during Z-Wave inclusion. If it was set to Multichannel, try to set it as Singlechannel. This problem was with Shelly Wave 2PM, dunno if the same applies to Motion sensor as I did not test that one.
Btw, try Shelly support. They should have Fibaro Home Center 3, so they can tell if something needs to be done.
Maybe this helps.
Edited by jakub.jezek
    Hi m.roszak, pls find attched the logsDump. Thanks!
    Tried this one from jakub.jezek - LUX works, Motion Detection does not :-(
    Edited by awlieser
    So, I see in logs reports for motion detection and its cancellation but no mapping those to any device tile in the system - somehow correlation between this class and created entities in the system is not created.
    Device reports support for this in Notification CC v8 which should be handled properly.
    It may not be an issue with the device itself but I am no developer so can't be sure.
    I will report it for the analysis for the team, not sure how fast they will look into it as this is a vacation period.
    Keep you posted.
    PS
    Node 72 (system ID 1456) is spamming a lot with wake up notification frames which triggers polling for the states for this battery operated device.
    Look into this one, it stresses your network ;)
    Hallo, gibt es hier schon eine Lösung für den motion sensor? Ich habe dasselbe Problem.  LUX funktioniert, Bewegungserkennung nicht :-(
    In general, the firmware quality of Shelly Wave products is, let’s say, rather poor. Some modules lose their calibration data, others experience connectivity issues - regardless of whether i use zw2, zw3 or HA. Certain devices also fail to report classes or events correctly ... so yeah mix of issues.
    Yes, one can include them in most cases successfully, and with some luck - if the firmware is up to date - they do work reliably.
    Unfortunately many distributors still ship these devices without the latest firmware installed.
    Therefore I strongly recommend updating all Shelly Wave products to the latest available firmware, before using them:
    Yes, there is still no firmware update available for the motion sensor (yet)
    W dniu 12.11.2025 o 13:50, tinman napisał:
    latego zdecydowanie zalecam aktualizację wszystkich produktów Shelly Wave do najnowszego dostępnego oprogramowania sprzętowego przed ich użyciem:
    Witam, a wiesz jak to zrobić z poziomu Home Center 3 ?
    Mam parę sterowników do rolet i na pewno trzeba je aktualizować
    Hello, do you know how to do this from Home Center 3?
    I have a few roller shutter controllers that definitely need to be updated.
