So, I have tinkered a bit more with an MCP server for the HC3. Now that VSCode has pretty good support for mcp servers it starts to be interesting.
My current attempt:
I typically run it with Claude Sonnet 4.
The mcp gives the agent access to the HC3 and it can do most tasks, like:
User:
Agent:
Have a look at the link for provided tools/features.
  • Like 10
  • 2 months later...
Awesome!
Great feature, two questions
1. is it works with HC2?
2. Is it works with multiple HC3 hubs? if yes, how?
Edited by cag014
    1. Not really, QAs are very different, as are scenes…
    2. No, it will use the .env creds to find the HC3. Need to swap .env and restart mcp I guess.
    Just install HC3 MCP in vscode - OK
    Updated settings.json with the right information ("FIBARO_HOST","FIBARO_USERNAME","FIBARO_PASSWORD","FIBARO_PORT") and the path to:
     "/Users/ASUS/.vscode\extensions/gsonsoft-development.hc3-mcp-server-1.0.4/out/mcp/fibaro-mcp-server.js"
    Then restart Vscode, and test connection to HC3 and get:
    Successfully connected to Fibaro HC3! Host: 192.168.1.107:80 Version: Unknown Serial: HC3-00006080 Config source: ~/.env file
    But I have an error message when I start a chat: The command "node" needed to run Fibaro HC3 Smart Home was not found.
    In the OUTPUT window I have:
    2025-11-12 13:55:34.396 [info] Starting server Fibaro HC3 Smart Home
    2025-11-12 13:55:34.397 [info] Connection state: Starting
    2025-11-12 13:55:34.398 [info] Starting server from LocalProcess extension host
    2025-11-12 13:55:34.435 [info] Connection state: Starting
    2025-11-12 13:55:34.438 [info] Connection state: Error spawn node ENOENT
    What I need to look at to fix this?
    You have https only to HC3?
    No, http & https are allowed
    I can connect with http://192.168.1.107 or https://192.168.1.107 or http://hc3-00006080 or https://hc3-00006080
    Ok, I read your error message again - it seems like you haven't node.js installed in your system.
    The mcp is written in javascript and requires node.js to be installed.
    Therefore the
    Done and the node error disapeared 🙂
    I am still not able to use it as when in a chat I ask "List my HC3 devices" (or any other request) I am always gettng an answer that Copilot cannot access to my HC3. Same if HC3 MCP server.js is declare in context field.
    Is it because Copilot didn't use HC3 MCP?
    Do I need to have a running lua file before asking this quetsion?
    I have the MCP server up and running. It's fun, I can now change the color of my Hues' with natural language :-)
    node.js was missing on my system, too, suggest to add it to the install instructions.
    Try Command Palette -> HC3 MCP: Test Fibaro HC3 Connection
    Ys I did and getting this result:
    Version: Unknown
    That's odd. What's the exact message? Did you ask Copilot why HC3 cannot be accesses?
    Edited by jayrock
    I have set up the MCP server with login information and get a success message when I run the Test Fibaro HC3 Connection
    When I enter a simple request in the chat such as "show HC3 system information" or "show HC3 devices" I see an error of the form
    /monthly_2025_11/image.png.8d422e53a2027f9950c6b43ca80ea5d9.png" />
    The MCP server extension is enabled.
    Have I missed something in the configuration?
    For anyone seeing a similar error the problem was I was using an older release of node for another project. I updated to latest and it works.
