Cannot update 4.3->4.9
Hello. I have 2 old style FGT-001 with only one pinhole button. I try add this devices secure mode, non secure mode - - but anyway cannot update firmware.
I always got message "Error while validating the file".
Any solutions please?  May be need 2 stage update?  4.3->4.5(4.7) , then 4.7->4.10 ? But in this case i need firmware file
I also have 2 new style FGT-001 with button which can be pressed by hand (brown carton package) , and update 4.9->4.10 without any problem.
8 answers to this question
    As always, all done by myself..
    Yes , modern HomeCenter3Lite with Z-Wave 7 , etc. - cannot update my 2 FGT-001 with old 4.3 firmware!
    But , after remove this devices from my new HomeCenter3Lite and pairing with Old Scool very rare HomeCenterLite with old interface - my 2 FGT-001 start updating with very nice breathing LED effects (newer see this with modern HomeCenter3Lite!) - 2 step long update   4.3->4.9 , then 4.9->4.10
    Thanks Fibaro for your modern devices "super optimisation"...
    Thats sounds a bit disappointed, but I hope it isn't too personal.
    Glad you've found a solution and thank you for sharing. It will help others 👍
    Hi @Telefonist,
    If you can just let us know what z-wave engine version did you choose on HC3L? Is it 2.0 or 3.0 beta?
    You can check it by opening Swagger and select settings/info. Thanks!
    Thanks for that info.
    I have the exact same problem. Updating from version 4.3 to 4.9 won't work. Unfortunately, I don't have the hc2 or hc3l and I don't want to downgrade to Zwave Engine 2.0 :/
    I received information from support that if it doesn't work, I can send them the heads and they will update it.
    It would be nice if they solved this problem.
    11 hours ago, Sankotronic said:
    Hi @Telefonist,
    Hello . I have Z-Wave engine 2.0 on my HCL3
    Try variant remove your fgt-001 from pairing and add to controller UNSECURE mode (Without S2 security ). Then, try upgrade 4.3->4.9
    If upgrade  passed (final 4.9 or 4.10), later you can again remove and add FGT-001 SECURE mode
    thx i'll try that
