Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Elero
    DuoSON-868 device integration.
    AstroSON-868 device integration.
Nice*
     Cleaned up the system devices model for monodirectional devices by removing redundant device's roles.
Other
    Changed graphics for Energy Panel charts.
    Added Swagger documentation for /api/mobile/settings.
Scenes
    Possibility to send e-mails to Installer from LUA and block scenes.
Z-Wave
    Changed font colors in the Z-wave console for better readability.
Bug Fixes:
Climate
    Fixed issues when changing the temperature in cooling mode in the Climate Panel.
    Fixed time display in seconds for schedules.
    Fixed mode change from off to automatic after zone data change.
Devices
    Fixed a screen freeze in the device removal process in IOS mobile apps.
    Fixed slider performance in advanced device settings.
    Fixed the update of port settings and the operation of the save button in the interface when changing the protocol for cameras and NVRs.
    Fixed the interface appearance for the Association tab in the advanced device settings.
    Fixed display of device "families" in the device list.
    Aligned the Add Device and Remove Device modals.
    Fixed the appearance and readability of the Device Updates tab.
    Added missing toggle action for MultiPositionSwitch devices.
    Fixed the add DSK code button for Smart Start.
    Fixed the issue of displaying a message disconnected when the camera preview was working properly.
    Fixed saving of advanced settings when changing tabs in the device list.
    Fixed display of the "on" status for devices inheriting from the colorController type in the interface
    Unlocked the process of adding devices when Z-wave learning mode is enabled in the interface.
    Fixed display of device statuses in the history panel.
    Fixed display of device "families" division on the device list.
Energy
    Improved the readability of information in the Energy Panel in dark theme.
Other
    Fixed interface behavior when restoring Cloud Backup.
    Access Point is available again in Recovery Mode.
    Fixed errors when changing the language on the first screen of the FTI process.
    Removed redundant password entry attempt counter in FTI process.
    Removed redundant display of acceptance of Terms of service and Privacy Policy in the FTI process.
    Fixed display of the drop-down list in the profile menu.
    Adjusted the appearance of drop-down lists on the Network tab.
    Fixed the appearance and readability of schemes in Swagger
    Fixed redundant pop-up login screen after going through the FTI process in the interface.
    The save button is active again after setting a new location.
    Adapting the appearance of steppers to the new design.
    Fixed the appearance of the Update tab.
    Added missing icons for weather conditions.
    Minor UX/UI fixes.
Quick Apps
    Dropdowns in the Quick Apps preview are not expanded by default and it is possible to close them.
    Fixed text wrapping for labels.
    Adjusted QuickApp edit modal view and console icons to the new designs.
Scenes
    Fixed the appearance of the LUA editor.
    When creating a new scene from the Scenes Dashboard, the editing screen opens.
Users
    The "Continue" button is not active during the user deletion process.
    Fixed scrollbar functionality when editing user settings.
Z-Wave
    Fixed an issue where the “Check for updates” button was inactive after adding a Z-Wave device.
    Adapting the view of the Z-Wave 3 device update tab and Z-wave Diagnostics to the new design.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Devices
    The device "family" division on the device list does not work correctly in dark theme.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Security:
    Due to the EU Data Act regulation, changes have been introduced to enable the download Hub data and user data
    - from the Hub settings level
    - from the user settings level.
    The Privacy Policy and Terms of Service are accepted by every user, not just the administrator.
    Data submitted for analytics is available in Swagger for administrators.
    Improved crash dump encryption method.
  • K.Drozynski changed the title to FIBARO System Update 5.183 BETA for Home Center 3
