11thNuneaton 0
I want to change the default setting for one of the parameters (3) of the temperature sensor as below. When I look at the device settings there are no parameters listed and no template. I tried add parameter, but after doing it nothing showed. Any ideas?
Parameter 3: Set the temperature
reporting threshold. The sensor
will send a new temperature report
if the difference compared to last
reading exceeds the value set here.
Values: 0 (disabled) – 100 (degrees
where 10 equals 1 degree); Default:
10. Size: 1 byte dec
