The update is visible, I click update, agree to everything, backup, installation, restart, but after the system boots up, the original version is still there :) Any advice? Thank you.
Maybe first do the (full) backup, then do the update without the backup option.
    Of course, I've already tried that. And the result is the same.
    /monthly_2025_09/image.png.4d78fce467402cd5972ce3401ef018b5.png" />
    @petro_cz , How are you connected? Updates do not work while connected via Fibaro/YUBII ID. Update can be done localy only.
    :)))))))))) Sure, locally, it shows me this after the update is "complete."
    You could try to force (workaround not a solution) the right update with Swagger (download and install).
