Is it possible to create one slider with two runners in a VD on HC2
I have several Hunter Douglas Duettes in my house connected with a Powerview Hub2 to my Fibaro HC2.
I can set the bottom and toprails to any desired position without using the Powerview scenes using LUA-coding.
But since on a Duette the bottom rail and top rail are set separately, I need two runners to set them. I currently have two sliders for each Duette.
Obviously they cannot pass eachother, so I check the values of the sliders against eachother.
Would be nice if I could somehow set the runners on one slider only.
Can the UI be adapted to get this done?
Edited by GeNie
