vdvs 0
Hi all,
First post, so I hope I'm following the rules.
My hc2 died so I upgraded to a hc3.
When I try to enable a scene via double click it works. When I try to run it again it doesn't work. Then enable the light (by pressing once the switch) and it's working again.
After Google and AI told me it's related to "sceneActivation" and I should use "centralSceneEvent" because it's more stable in the HC3.
I've created the scene below but the scene isn't activated. I've tried all the id's within the familiy, but 93 is the one that works with the sceneactivation property. (so I assume this is the right one)
Nevertheless, it's frustrating that I can't make it work.
Could someone tell me what I'm doing wrong?
