Like the app update log says, the favorite tab is stored on the hub. Is it access able somewhere with the api/swagger in an json format maybe? :D
it is no info about it under the device id of the phones 🤔
May I ask you about this to @m.roszak ?
May you check about this? :D
So, it was planned as typical Yubii App internal feature but I don't see why not share the API, its super easy to use:
GET /api/mobile/settings/  - list of all stored configs
GET /api/mobile/settings/$uuid - configs for specific device
PUT /api/mobile/settings/$uuid - updating
DEL /api/mobile/settings/$uuid - deleting
We will add this into the swagger in 5.191.
    Thanks works like a charm!! :D
    • 5 months later...
    That's a cool way of getting some info on the mobile app
    In my case I'm looking to get the app's "skin" parameter in order to apply some color scheme to my QA accordingly.
    @m.roszak do you know if the app's skin/theme "dark" or "light" preference will someday be shared in the Json of /api/mobile/settings/$uuid ? It's not the case now, but could it be suggested for some next release ?
    Ah, its for now local phone setting not related with the hub in any way - I will put it in the backlog as an idea.
    For now, if you are using the same theme in web and app - you can base your theme in QA on hub settings.
    1+. I agree with @fel-x we should have the light/dark from the mobile to :D
    This is exactly what I'm doing :-)
    My QA is checking the "skin" parameter on the hub and adjusts colors according to it. It's very nice on the web UI.
    I was writing a function to adapt the colors on the app in case the QA is running on the app, but since there is not (yet) a solution to check user's preferences on the app, it will be based on the Hub setting.
    Of course not everyone uses web and app identical theme/skin settings...
    So thanks for putting the idea in the backlog 👍
    it will definitely make my QA's look better for eveybody.
    Edited by fel-x
