Help! Problem to obtain the list interfaces ethernet/WLAN connectios witch api.get command
I'm having trouble getting the list of network connections from my HC3. I use the api.get("/settings/network/connections") command, but it doesn't return the list in table format. I should mention that I'm connecting remotely to the HC3. I think that the URL is not well but i am not sure. Could anyone help me? Any help would be appreciated. Thanks in advance!
6 answers to this question
in quickapp you can use:
Edited by lux
Hi @Herni,
I use this code to check existing gateway connections and get IP address:
Note that above code works on both HC3, HC3L and Yubii home.
To check connection to the internet:
Above code is simplified. My is a bit more complex because it stores time when internet went offline and time when internet get back online etc.
@Sankotronic Yours is more easy:
/settings/network/connectivity works well, but can be a bit slow to update. If you are in a hurry try to connect yourself to a known endpoint.
The problem with ip address is that we in theory can have more than one. I usually use something like this
It returns the ip and true if found I/F matching and otherwise returns a I/F enabled and false.
Usually one wants the (lowest) wlan enabled, but some user may have eth.
@Sankotronic, your version seems a bit strange, the first if branch is always true (if net.networkConfig.eth0~=nil) and will then give wlan0 if eth0 not enabled. The other branches are dead code.
In theory a wlan/eth I/F could be enabled but not have an address if something went wrong with dhcp...
                  Hi guys,
                 Thank you so much for yours responses. I really appreciate it very much. The problem was the sintax of the URL of api.get() command. Thanks guys!! :)
    On 10/5/2025 at 9:34 AM, jgab said:
    Hello @jgab
    Would you allow me to use your code for getting the Box IP in my next QA ?
    I will credit you of course.
