Hello @m.roszak,
The job developer team did on this last update is almost excellent.
Of course there are still some things that need checking and correction or improvements and I believe will be done in future updates.
One of the things that needs correction is notifications from devices. I have one child device of type com.fibaro.temperatureSensor with below settings:
29th notification is something else :-)
If I remember correctly there was some complaints in the past about this problem. I'm not complaining, just informing you since I agreed to test beta releases by installing them :-D
Thank you!
I suppose that it will send once per hour if threshold is reached (and value stays there). If the value will go back and reach the treshold again it will send it again.
We will check it anyway to make sure that this is the case here.
    Hmmm, unfortunately I deleted all e-mails and notifications received.
    I just remember that temperature was bellow 1°C, actually even below 0°C. Will give it more attention next time when happen.
    BTW - low temperature threshold is set to 1°C
