modules do not appear in grafic scenes
Hi experts,
I'm having a problem with my modules and hope you can help me. When I include a new module, it appears in the module overview, but when creating a graphic scene, it sometimes doesn't appear. It works for some modules, but not for others. And I can't find any obvious reason for this.
How do I get these modules to appear when creating a graphic scene?
What modules?
    I reincluded a heating thermostat, but it happens also with other modules.
    By moduls you mean a zwave device..I suppose you included a zwave thermostat into you system. It got some child devices.
    Are you looking for one of them?
    Did the thermostat get included properly? Is it configured poreprly?
    Did you check visibility? Is the device dead?? Has it connection?
    Access rights???
    More info needed to help you..
    Maybe some sreenshot
    I have attached 2 screenshots. The 1st (modules) displays the thermostat (within the yellow lines) in the modules section. The temperature indication seems not to be configured. But I have no idea what I shall configuere there. I have another identical thermostat and it rund without additional configuration.
    The second screenshot displays the try to create a grafic scene. But the thermostat do not appear.
    It'spoosible to set the temperatur, to switch between heat, off, max etc. It all run, but it not appear in the grafic scene.
    Do you have any idea what's the problem or, if it's the reason, how to configur the module.
