fibaro.homeCenter.notificationService() still not working! Whaaat?
Hi @m.roszak,
Just tested this function and found that is useless.
I wanted to send "MobilePopupNotification" with following code:
Above code does not work in quick app.
When executed I get following error:
[09.10.2025] [18:43:00] [ERROR] [QUICKAPP37]: QuickApp crashed[09.10.2025] [18:43:00] [ERROR] [QUICKAPP37]: main.lua:30: attempt to index a nil value (field 'homeCenter')
When run from scene, then it seems it works and debug is:
[09.10.2025] [18:47:45] [DEBUG] [SCENE5]: response: {"wasRead":false,"recipient":2,"priority":"info","id":3,"created":1760028465,"canBeDeleted":true,"data":{"text":"sampleText","buttons":[],"title":"sampleTitle"},"type":"MobilePopupNotification"} code: 200
but I get only this in GUI:
and there is nothing received in Yubii Home mobile app latest update.
So @m.roszak, any comments on this one?
Am I doing it wrong, or this part is still not finished since 2020?
fibaro.homeCenter hasn't been implemented for QAs (don't ask why they have 2 different sdks...)
fibaro.homeCenter is there for scenes but has it ever worked on the HC3?
What has worked for me in QAs in the past is using api.post("/mobile/push", ...)
I tested now and the message appears on the mobile but then when pressing "YES" I get an 'Info: Sending action "..." failed' response on the mobile.
Either it's temporary or something broke.
This is actually easy to explain but I don't think you will be super happy with the answer, it is not finished becasue it is not supported and was not planned to be supported in new platforms - this should never been listed in the supported notification types in Lua scenes documentation.
Those mobile popup notifications was designed to work with the oldest Fibaro App and HC2/HCL hubs, Yubii Home Center / Yubii Home apps does not handle those the same as webUI does not support those.
Keeping this function in Lua scenes (handling) is another topic, it should be removed.
We will check it out.
So the interactive push with YES_NO, made a callback when pressing YES. (iOS)
However, when pressing NO there was no callback.
Used to solve it with a timeout waiting for the callback, but it would be nice it it called the actionName with false.
    Hi @m.roszak,
    Thank you for swift answer. I'm now busy with making Advanced Notification center QA so I'm just checking what can be used to send them. It is not that I'm missing popup notifications :-D
    BTW - maybe it is time to update developer information?
