Hi is possible add my yubi home center zo apple home kit? I’m using yubi to controll my exterior blinds with elero motors and two nice garage doors and any shelly smart devices. Its possible all this intergrate to apple home kit when my yubi home center dont have apple home kit code? Thanks.
Suggest you have a look at Raspberry Pi . It can be programmed from scratch or there is a pre programmed unit that I use called Automation Bridge. It works seamlessly with Fibaro HC3 . I use it to provide voice activation and for location use. I the downside to HomeKit is that there is no backup . I put all my scenes into HC3 first and then use the Raspberry Pi to activate those scenes by voice. For manual switching.  I use the Yubii App directly. Using the Yubii App as much as possible keeps the systems simple .  Hope this helps.
