HC3 update, now I can not turn devices off or on in scene
After the latest update (16th Ocotber 2025) I can no longer simply turn lights on or off in a blovk scene. That option is no longer available. What a, I doing wrong?
If I create new scene:
check your eettafel (lamp)
  • 4 weeks later...
I have the same issue with all roller blind controllers and every dimmable device. Annoying, what to do?
Thx & best
Axel
Hi all,
is there any solution here? This is quite annoying due to the fact, that I have a plenty of fibaro dimmers (dimmer 2) and I am not able to change the behavior.
Thx
Axel
thank you for your report. We will look into the issue you mentioned.
Best Regards
Tomek
@ursusbv @AxelS I did send you a private message, please check it out.
We cannot reproduce the issues and we would like to take a look.
