Quote
The update was not performed due to an incorrect system image verification. If the update was performed manually through the system Recovery, please ensure that the correct version of the system was used.
Edited by flacon030
  • flacon030 changed the title to Updated error message
Hi @flacon030! Thanks for reporting this. We’re aware of the problem and the team is currently working on it. Really appreciate your patience while we get this sorted out!
Best regards,
Gonia
Fibaro Team
    Good morning Thank you for your response
    I just found a solution
    I went back to version 5.182.27 then I updated to the latest version
    Sincerely
    Edited by flacon030
