Help with QAs..
Hi Everyone,
I have just managed to go from HC2 to HC3 and im having problems to port a Froggit weather station (using Ecowitt API) to use QA.
The HC2 implementation was to query Ecowitt API and store all information into global variables but since i now understand i should instead use QA and child devices to store these instead, i have looked into several tutorials but for me its a bit messy and i cannot fully grasp the "QA" way yet.
So i was hoping if a kind soul could help me (Im getting old) with a simple way of creating a QA with a child device and then how to create the label, updated with values?
The net.HTTPClient works so i can fetch all devices and values but is there someone who can explain how i create, initialize, a child device and also how i populate it from the API response?
BR
i have created QA for Froggit / Eccowitt, however haven't released it to public. Generally only for DP2000 Pro 7-in-1 version,
but of course it can support other models too. What not yet supported is automatic detection of extra attached sensors, so when need to add them extra in code.
I will send you PM with the QuickApp.
    @tinman That sounds great!
    Many thanks for that!
    BR
    On 10/30/2025 at 3:33 PM, 747 said:
    Hi Everyone,
    BR
    I am curious, what for you need child device? To my opinion create two QAs, better control and monitor
    When i read the tutorial from Fibaro, i understood it as i should use childs for different sensors.
    Like a Weather station which is the parent, and then create childs for all the different sensors, Wind, Temp, Humidity, rain, etc. but i could of course have misunderstood it..
    BR
    BR
    I don't see any reason why... in any case you need to control the child to send the data of the sensors, Full QAs allow complete control over GUI elements, logic, and device behavior.
    A single QuickApp (QA) in Fibaro HC3 can handle all communications and update other QAs using hub.call(). This centralized approach is powerful, especially for advanced users who want full control over logic and messaging. In addition, it is reducing overhead: No need to manage child device states or metadata.
    You cannot add custom buttons, labels, or sliders to the child device’s UI.
    You cannot define custom views or layouts for child devices.
    Just make sure to create proper type of QA (switch, sensor, energy meter and etc.)
    But at the end it depends on your needs.
    Edited by cag014
    Actually, child devices do support custom UIs like ordinary QAs since some time ago, that's why we have the copy JSON view button in the editor.
    But, I do think that it's much more efficient to use main QA and children than just a bunch of QAs.
    Each QA on the HC3 runs its own linux process and its own Lua vm. If we have children, all the Lua code runs in the "mother" QAs process and Lua vm.
    You are absolutely correct. But the children are also bunch of QA.
    Regarding the "Copy JSON View" button in the editor as far as I know does not work for child devices directly. It only applies to the parent QuickApp you're editing.
    I do think that in some cases you need to use children lik Multi-device integrations, modular control, cloud APIs it is easier to manage large systems where many devices share a common backend.
    Edited by cag014
    Yes, but the saving is that they share lua vm and linux process...
    For the custom UIs
    that is definitely bad advice, two or more QAs accessing the same weather gateway via http, instead of one calling all updates and refreshing child devices.
    Generally some http/tcp devices does not support multiple calls, or udp can bind only one port ... the overhead to let multiple QAs to work in such cases properly is much higher than understand and create QAs with child devices.
    Edited by tinman
    4 minutes ago, tinman said:
    that is definitely bad advise, two or more QAs accessing the same weather gateway via http, instead of one calling all updates and refreshing child devices.
    Not at all, read carefully: I suggest that just one QA accessing weather gateway via httpand updates others. Same as you update and refreshing child devices. Use hub.call(QAID, funcName, parameters....)
    Edited by cag014
    Just go through the forum and see how many users have problems with creating and update/refresh children.
    🧩 Option 1: Two Separate QuickApps
    Pros:
    • Clear separation of concerns: Each QA can have its own logic, lifecycle, and purpose.
    • Independent updates: You can modify one QA without affecting the other.
    • Modular testing: Easier to isolate bugs or performance issues.
    • No shared UI: Each QA has its own interface, which can be confusing for users.
    Cons:
    • Harder communication: You need to use hub.call() or global variables to sync state
    🧩 Option 2: One QA with Child Devices
    Pros:
    • Centralized logic: All control and updates happen in one place (onInit, loop, etc.).
    • Simpler communication: Use self:getChildDevice(id):updateProperty(...) directly.
    Cons:
    • More complex parent QA: Logic can get dense if you manage many children.
    • Limited child UI: You can’t add custom buttons or sliders to child devices.
    • Harder to reuse: Child devices are tightly coupled to the parent QA.
    but in that case you wasting resources and create unnecessary load. And what about 10 QA limit on HC3L or YH? The weather QA the OP is talking about is using already 10 child devcies ...
    The question raised about HC3 not HC3L or YH. By the way these hubs are limited for number of devices also and doesn't support Zigbee
    As I said, this is an option that you don't need to mess with children.
    Edited by cag014
    Hi Everyone,
    BR
    @747
     May I suggest using AI to deal with children? Believe me AI knows all you need about HC3, AI actually can write for you the code and it does work.
    In my case I use Microsoft Copilot (free of charge) which is bult-in in windows and Edge browser.
    Takes just a few seconds to get code and answer. Use Smart (GPT-5) option
    Works like a charm....
    Edited by cag014
    Pros:
    Cons:
    I thought cag014 was a user of flesh and blood. But now we know cag014 is the first AI Bot on the Fibaro forum. Yesterday The Terminator was on Dutch television. it's getting very close now.
    Yes, the options list must have been AI generated as it didn't make much sense ...
    Also what gave it away was the AI self bragging
    I am flesh and blood and not afraid or intimidated by AI.
    Ok, thanks to @tinman and of course the very good suggestion from @cag014 to use copilot i think ive got some progress now and understands a bit more when playing around with QuickApps and Childs.
    I do however have some problems when trying to generate child instances.
    For example i get the below error:
    Class for the child device: 4189, with type: com.fibaro.temperatureSensor not found. Using base class: QuickAppChild
    Which i dont understand since "com.fibaro.temperatureSensor" is spelled correctly and i have tried to create the classes both in the "onInit" function and also outside of it.
    And i shouldnt be needing to have 2 child classes pointing to the same device (temp sensor).
    The below only creates the first instance (MatsalTemp) but with above error..
    class 'TMatsal' (QuickAppChild)
        function TMatsal:__init(device)
            QuickAppChild.__init(self, device)
            self:debug("TMatsal init")
        function TMatsal:updateValue(value)
            self:updateProperty("value", value)
        class 'HMatsal' (QuickAppChild)
        function HMatsal:__init(device)
            self:debug("HMatsal init")
        function HMatsal:updateValue(value)
    self:debug("Creating child devices..")
        -- Temperature Sensor
        local MatsalTemp = self:createChildDevice({
            name = "Matsal Temperature Sensor",
            type = 'com.fibaro.temperatureSensor',
            unit = "C",
            initialProperties = {
                value = 0.0
        }, TMatsal)
       local BeasementTemp = self:createChildDevice({
        name = "Basement Temperature Sensor",
        type = "com.fibaro.temperatureSensor",
        unit = "C",
                value = 0.0
        }, HMatsal)
    sounds like you are doing init with wrong names instead of class, try following:
    Edited by tinman
