petro_cz 32
Hi, I have a small problem this heating season. When the temperature schedule changes and all thermostatic heads need to be reset to a different temperature, some of the heads do not reset and the hourglass icon remains lit at their set temperature. However, when I set the temperature manually, the temperature changes and is transferred to the app. This never happened last year. Has there been a change in the software where it doesn't check if a temperature change has been made? Sometimes the hourglass doesn't even appear and the old value remains! I would assume that Fibaro continuously checks the temperature settings. Can anyone explain this to me? Note: the heads communicate normally, but I cannot rule out the possibility that when the temperature changes, the Z-Wave network becomes overloaded and some heads do not receive the signal. In that case, I would expect continuous monitoring and correction. Thank you.
