Can not login to cloud, with valid user and password . ( I didn't change nothing)
Can not login via Yubii app to my account. I try to use  valid user and password .  I didn't change nothing.  Also login via web browser to server doesn't work.  Getting error wrong user or password.   Locally I'm able to connect to my HC3.
Edited by Peter Mahut
In hc3 settings
> acces > check if remote acces is still enabled.
check in Network if LAN or WiFi is connected to the Internet
if notting helps contact [email protected]
    Thank you .  I've checked all that settings and everything was  set correctly. But still not works. It seems like my password was somehow reseted on server :)  without my interaction . But locally I can login with that password.
    Are you sure you use the right credentials for remote login? They aren’t the same as the local login.
    Thanks for tip.  Yes I believe,  I'm using right credentials.
    I can see in settings , that there is an option to set local credentials and understand that these can be two different strings, but I have set the same string for all / both. Motivation was to have easier life and remember only one password for Fibaro world. :)
    At the end I will probably need to reset the password , but don't understand how it is possible that it was changed or reset without my interaction. It seems like this for me.
