Lua code: making Alarm when switch has no
This Lua scene won't start, do I see something wrong?
Can someone help me?
Devices:
Home centre 3 Lite
Fibaro Double switch
Aeotec Alarm
script: when power looses double switch then activate alarm, when power is back deativate alarm.
5 answers to this question
please take a look at the documentation linked below — it should clarify the basics and make your next steps easier:
Edited by marczu_83
This looks like a mix of Homecenter 2 script in a Homecenter 3 script. That won’t work.
You could start with the above manual. You could also create a blockscene and convert it to a lua scene to see how it turned out in lua.
    @SmartHomeEddy there isn't any trigger by blockscene when power drops, and the build is by monitoring the double switch.
    I'll think that the fault build in the trigger the point of state is. I'llhope
    But if the conditions look like HC2 scripting, how does the lua code looks like?
    I"ll think there is something missing in the condition or trigger.
