Fibaro ID not conneted - cloud backup not reachable
can any help me out?
Unfortunately the fibaro id is not connected and I don't know where to connect it.
My HC3 is wired.
When looking at the cloud its active.
How do I connect to HC3 with my fibaroID?
Thanks!
Edited by Carsten6000
It's a long time ago for me but as you can see in the cloud there is no user?
I guess you did not  fill all tabs in.
Walk again through install.
If local install HC3 is done you can go to cloud.
Succes
    @sjakie - Thank you for your answer.
    I'm not sure how to walk through the install again?
    Could you elaborate on it? Maybe explain it in detail?
    I would like to prefer to avoid a factory reset since I then have to add all devices again.
    see here do each step
    @Sjakie have allready tried the procedure - but still no connection.
    What happens if add a user? I think that's the way to connect user after logging in Yubii?
    @Sjakie Still the same. Did even try to install another HC3 that I have - same problem no connection.
    I am sorry to be out of ideas.
    Create a Fibaro support ticket
    Edited by Sjakie
    With two HC3 having same problem on the same home network I start looking at the network and ISP security setup.
