Change climate mode in QA (api.put) - stop working
I´am using this code in QA to control climate zones, but it stopped working some weeks ago... :-(
I need to change climate mode from Scheduler to Manul and vice versa, it was working for more than 2 years, but not now.
Is there somebody with the same issue?
    local panel = {1,2};
    for i, climate_id in pairs(panel) do
    local climate=api.get("/panels/climate/" .. climate_id)
    local status_mode = climate.mode
    self:debug("climate.mode:"..status_mode) --for test
    climate.properties.handSetPointHeating = 25
    climate.properties.handSetPointCooling = 70
    climate.properties.handTimestamp = 4294967295
    climate.properties.currentSetpointTimeStartHour = null
    climate.properties.currentSetpointTimeEndHour = null
    climate.properties.currentSetpointTimeStartMinute = null
    climate.properties.currentSetpointTimeEndMinute = null
    climate.mode = "Schedule"
    api.put("/panels/climate/" .. climate_id, climate)
Thank you for your help...
  • 3 weeks later...
I checked what payload the browser sends when changing the schedule through the GUI, and this is what came out.
endpoint
when setting manual mode
return to schedule
  • 3 weeks later...
Good morning,
I had the same for some zones.
What I did to get the rest working is changing the zone once by hand to vacation and then back to schedule. After that I could change the zones like above.
Jim
    Thank you very much to all, it helped me to solve this issue with climate panels. 👍
