Retrieve SceneID and assign as local variable in LUA Script?
I'm trying to retrieve the SceneID from the LUA scene itself when executed.
I want to use it in my debug outputs like
fibaro.debug("Scene" .. localSceneID, "My Message")
But fibaro:getSelfID() that apparently was functional in HC2 is not present as a method in HC3.
I know I can simply hardcode this - but I'm looking for a dynamic universal solution that will work in LUA scripts and in QuickApps. Obviously, I need to accept if the solutions are different.
Any useful ideas or experiences on how to do this?
Use sceneId, available inside the scene.
For example you can get the name of the scene by using:
You can use:
fibaro.debug("Scene" .. sceneID, "My Message")
sceneId, with capital 'I' and lowercase 'd'
Yes of course you are right. Thank you.
fibaro.debug("Scene" .. sceneId, "My Message")
