Unknown error occurred: no static 'logLevel' in class 'QuickApp'
After beta update i am getting this error from the Velux quickapp
Anyone has any solution?
[14:11:23] [ERROR] [QUICKAPP2072]: Unknown error occurred: no static 'logLevel' in class 'QuickApp'
So, somewhere in the code, there is an attempt to access QuickApp.logLevel
Ex.
Because classes created with the 'class' function, like QuickApp, will throw an error if we try to access a "class variable" or "static variable" in a class, and the variable is not defined. (It works for the QuickApp instance we access with self, but not for the class QuickApp)
So, this may be a bug where the author is meaning self.logLevel.
It could also be that he intended to use a class variable, QuickApp.logLevel, but he initializes it in one QA file and access it in another QA file, and the load order of the QA files have changes so he tries to access it before he initializes it.
Is the QA encrypted? If not you can make sure the class variable is initialized to something before accessed...
    Ex.
    Yes, my very first attempt was to look for any occourence of logLevel in the code..There is nowhere logLevel used in the entire code..That's why this is strange. And it did not happen before the new beta fw..So another mystery...
    Edited by Neo Andersson
    Its not encrypted...but i have no clue what else to do..I searched for the logLevel usage throughout the entire code..nowhere found..unless there is some possibility to hide a file from users that i don't know of..
    I saw something about changed debug behaviour in the last beta change log, maybe this is related to it
    Maybe somone from Fibaro can take a look into it..
    So, then it may be the same kind of error but in Fibaro's new beta FW...  maybe related to the new debug functionality...
    and it only happens in very specific cases, like in the Velux QA, as I haven't seen it yet in my own QAs...
    Can you just try and add
    in the main QA file on top-level (NOT inside :onInit() )
    and see if the error goes away...?
    ohh, this is very strange...
    Having your line added, the error does not appear..
    and after that i removed your line,and the error still does not come up..
    What can I say - magic 🤓
