hub.alert() crashes QuickApp with "Wrong parameter type, string required. Provided param 'false' is type of boolean"
I discovered a critical regression in the 5.192.6 beta firmware when using hub.alert("email", …) from QuickApps.
**Symptom
Calling
(4 parameters – the most common syntax in many of my existing QuickApps) immediately crashes the QuickApp with:
The QuickApp stops completely (polling stops, no more logs until manual restart).
Works perfectly on stable 5.190.39 and earlier.
Workaround is to add a string to parameter 4 instead of false.
Hi @pvandamcom,
Please check here for changes regarding sending e-mails:
As you can see from above quick app hub.alert function is changed and there is no boolean parameter. You need to correct all your code and replace boolean parameter with e-mail subject.
To be honest, it never was any bool arg there in QuickApps - it was just ignored in the past.
    Thanks for this reference, I missed that.
    This is quite a change, I typically use 6 (scenes) or 4 parameters based on documentation I could find.
    And concluded the following order:
    1.  type
    2. user
    3. messagebody
    4. messagetopic
    5. priority
    6. sound
    Last 2 could be ignored, but learned that 5 needed to be "" and 6 false.
    Seems that the formal way is now:
    scenes - 5 parameters, --> 3 is body, 4 is priority, 5 is Subject?
    QA's - 4 parameters, --> 3 is body, 4 is messagesubject
