Why can't the climate function allow temperatures below 4C?
I ideally want to keep a space just above freezing, but have the capability to increase it easily when the area is in use.  I am using the climate function with a temp sensor and mains switch, which provides this function, but the minimum temp that can be set is 4C.  Is there any way that this can be reduced to 0 or 1?
I could write a couple of scenes to switch a heater on and off to maintain the desired temperature, but this does not have the simple way to increase it to say 20C when the space is to be used.
This is on an HC3
