All i see is
Did you tried to restart browser, reboot computer, cleanup cache of the browser, etc.?
    I tried Chrome and Safari, cleared the cache, and also tested it on iOS. It always looks the same.
    Hello, had this once. You will have to press and hold the "D" Button on the Backside for about 20 second's, the LED will turn Red, then you will have to press the "D" Button again. This will Reset the Network Settings.
    After a minute or so, the HC3-"Serial-Number" Wifi will appear. You have to reconnect your HC3L with your own Wifi the same way you did the first Time you got it.
    Are you using an LAN Adapter per chance?
    As a Reference:
