Hi, I would like to know if anyone is experiencing the same things as myself. I have 2 HC3 units, and after update 5.190 and higher, I have problems with the RGBW1 modules. I have tried to contact support but after a few reinstalls and so on, they stoped replying. The issue is, that if the module is controlled, after some while the HC3 services reboots. Took me a long time till I have identified what causes the reboots. When I stoped using the rgbw modules for lights in the house, the reboots stopped. Anyone else having the issue ?
Second , in the update 5.200 there was a change in the hub.alert commands in QA, and now it wants "true" as string, not true as boolean. Thats quite stupid to go through all the QA and repair the commands. But the issue I have is, that the QA arent sending email notifications, but from scene it is working fine.
hub.alert('email', {[1] = 962, }, 'Test Mail', false, 'Test.', true)
have tried all combinations of "true" false and so on. Till now, all notifications were working fine, but after 5.190>5.200 the emails stopped overall.
See for hub.alert() here:
    Oh I see, the syntax is different. Why not keep it unified ? Will try it.
    And anything about the rgbw modules ? I have 6 of them, and it looks like, the only way for me currently would be change them all for rgbw2...
