Fibaro Dimmer 2 compatibility with JUNG 1731DD physical dimmer (regulated phase on S1/S2?)
Hello everyone,
I have a wiring and compatibility question regarding the use of a JUNG 1731DD physical dimmer together with a Fibaro Dimmer 2, and I would appreciate some guidance.
The scenario is the following:
I want to install dimmable LED lighting in a bedroom.
Planned setup:
  • A standard JUNG wall switch sends the phase to a JUNG 1731DD dimmer.
  • The JUNG dimmer:
    • Receives the switched phase from the wall switch
    • Also receives permanent live (L) and neutral (N)
    • Generates a regulated (dimmed) phase output which goes to the LED load
  • This is a standalone physical dimmer, not a smart one.
My intention is to add a Fibaro Dimmer 2 in order to:
  • Switch the light on/off via home automation
  • Control the dimming level via home automation (if possible)
Here are my doubts:
  1. Is it possible to connect the regulated (dimmed) phase output from the JUNG dimmer to S1 or S2 of the Fibaro Dimmer 2?
    • My understanding is that S1/S2 expect a clean live signal, not a phase-cut / dimmed signal, but I would like confirmation.
  2. Is it safe or supported to place two dimmers in series (JUNG + Fibaro) controlling the same LED load?
    • Or could this cause malfunction or damage?
  3. If dimming from Fibaro is not possible, would it at least be feasible to:
    • Use the Fibaro Dimmer 2 (or another Fibaro module, e.g. a switch) only for ON/OFF control
    • While receiving the dimmed phase from the JUNG dimmer as its input?
  4. Alternatively, is the recommended solution to:
    • Remove the JUNG dimmer completely
    • Use only the Fibaro Dimmer 2 for load control
    • And use the JUNG wall switch only as a control input (S1)?
I am attaching the wiring diagrams of the JUNG 1731DD dimmer for reference.
Thanks in advance for any clarification or similar experiences.
1. No.
2. No.
3. No, unless you use a device with a relay only eg Fibaro Switch
4. The proper approach is to take out the Jung and add the Fibaro.
    Thanks for your reply Tom, option 4, I would like to have a physical regulator, I can only control fibaro from mobile. Perhaps option 3 will be the way. What do you think?
    I think the best solution is to use a JUNG momentary (push) switch together with the Fibaro Dimmer 2.
    I didn’t know this function before, but as I understand it, by keeping the push button pressed for a certain time (1s, 2s, etc.) I can regulate the light level.
    A short press is ON/OFF, and a long press increases or decreases the brightness, stopping when I release the button.
    So in practice, this allows me to adjust the light percentage in a similar way to a rotary dimmer, but using a push button instead.
    Please correct me if I’m wrong, but this seems to be the cleanest and recommended setup:
    one physical dimmer only (the Fibaro), and the JUNG switch used just as a control input.
    If the Jung switch is just a momentary switch, then yes, using it to control the Fibaro Dimmer will work. 😀
    • 3 weeks later...
    I use Fibaro dimmer 2 with double momentary switches and it works great. With momentary switch S1 it is possible to turn on/off and change dimming level and with secondary switch S2 I use scene activation to do 3 different actions when pressed.
