Im trying to figure out how to add a non standard unit for a QuickApp child.
I want to present "dBm" and "Hz" after the values but cant get it to work.
I have used an instance of the com.fibaro.multilevelSensor for it.
Code when trying to set the unit and value:
 self.childDevices[key]:updateProperty("value", { value = jsonTable[1]["Structure"]["Devices"][1]["Device"]["HeatPumpFrequency"], unit = "Hz"})
self.childDevices[key]:updateProperty("value", { value = jsonTable[1]["Structure"]["Devices"][1]["Device"]["WifiSignalStrength"], unit = "dBm"})
But it doesnt seem to work at all, is there another way to do this?
I have also tried to set it when creating the child but it doesnt work either..
BR
5 answers to this question
    Sorry, had bad syntax. Works now!
    btw you could also consider using the framework (QwikAppChild) from jgab. Works great!
    Thanks @SmartHomeEddy, will look into that!
    Another question that just popped up, how do i find out what number an icon gets when added?
    I want to updateProperty "deviceIcon"..
    Right mouse click on the icon and Save As. Then you see the number.
