Jbuer 0
"The Aqara – W500 Smart Floor Heating Thermostat does not integrate correctly into the HC3. It appears as an on/off switch, a temperature sensor, and a humidity sensor.
However, the on/off function does not work; it only displays the current status and energy consumption (watts).
No data is being received by the temperature sensor, whereas the humidity sensor works as intended."
