QuickApp selection problem
I created a QuickApp device where I’m also using a selection-type UI element. In onInit, I’d like to preselect certain items in the selection based on a config, but for some reason the items are not getting selected from the list. Could someone help me figure out what I’m doing wrong?
Thanks for your help in advance!
Gateway type: HC3
Software version: 5.200.13
 5.200.135.200.135.200.135.200.135.200.13  5.200.13 5.200.135.200.13
Relevant code:
function QuickApp:onInit()
    self:debug("onInit")
    self._initializing = true
    -- configurate multi selectors for opening and closing blind list
    local opts = buildOptionsByAllShutterDevices()
    self:updateView("select_openingShutters", "options", opts)
    self:updateView("select_closingShutters", "options", opts)
    -- load shutters config
    local raw = fibaro.getGlobalVariable("blindsConfig")
    self.blindsConfig = raw and raw ~= "" and json.decode(raw) or {}
    -- select in seletors the shutters as it's in config
    self:updateView("select_openingShutters", "values", self.blindsConfig.openingBlindIDs)
    self:updateView("select_closingShutters", "values", self.blindsConfig.closingBlindIDs)
    self:initializeSlider("slider_weekdayOpeningTime", "Weekday blind opening time (hh:mm)", 0, 48)
    self:initializeSlider("slider_weekendOpeningTime", "Weekend blind opening time (hh:mm)", 0, 48)
    self:initializeSlider("slider_closingTime", "Blind closing delay after sunset in minutes", 0, 120)
    self:updateWeekdayTime(self.blindsConfig.minOpeningTimeOnWeekdays)
    self:updateWeekendTime(self.blindsConfig.minOpeningTimeOnWeekends)
    self:updateClosingDelay(self.blindsConfig.closingDelayAfterSunset)
    self:setDirty(false)
    self._initializing = false
blindsConfig global variable looks like this:
    "minOpeningTimeOnWeekdays": "07:00",
    "closingDelayAfterSunset": "30",
    "openingBlindIDs": [
        "135",
        "140",
        "130"
    "minOpeningTimeOnWeekends": "09:00",
    "closingBlindIDs": [
        "51",
        "123",
        "130",
        "135",
        "140",
        "147",
        "152"
Edited by Yetike
mispelled a word
Hi, if you are talking about dropdown list element, to select default item use this
