Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
KNX integration
From now on, your KNX system can work even smarter thanks to integration with our Yubii Home Pro and Home Center 3 hubs. Gain full control over lighting, switches, RGBW controllers, and sensors within one unified ecosystem.
What's new:
Devices
    Improved display of device families on the device list so that child devices are always located under their parent device.
Elero
    Integration with ELERO Lighting Receivers: TTDTW-E (Combio-868 LI W), TTDRGBW-E (Combio-868 LI RGBW),  TTDW-E (Combio-868 LI PW).
Gateway connection
    When the Slave hub is turned off or there is no connection, the devices added to it are visible as inactive (dead) in the Master hub.
Nice*
    Upgraded NICE chip firmware version to the newest one.
Other
    Added the information about the zone where the alarm occurred.
Scenes
    Added a new scene activation/deactivation block as an action in block scenes.
    Added possibility to enable/disable local and remote device protection via scenes and profiles.
Z-Wave
    Adjusted parameters templates for sensors to reduce number of reports for various devices.
    Fixed setting of parameter 5 for the MCO Home MH7H-EH device.
    Improved clearing Z-Wave network reset procedure.
Bug Fixes:
Backups
    Fixed an issue where the “Update and restore” buttons for backups with higher software versions were inactive.
Climate
    Fixed an issue where the schedule was not cleared from the Heat-Control/Fibaro Heat Controller when it was removed from the climate zone.
Devices
    Fixed an issue where the Color component view was not updating correctly.
    Fixed an issue with changing icon for Dahua cameras.
    Improved performance for the DoubleDimmer-Control binding Wizard.
Nice*
    Fixed setting favorite position for the screen devices which does not support this natively.
Other
    Removed a non-functional option (checkbox) for sending notifications on the list of mobile devices.
    Fixed visibility of device name when adding Z-wave devices in the mobile application.
    Fixed tooltips positioning in the interface.
    Fixed the message screen displayed after using the factory reset option in Recovery mode.
    Minor UI/UX fixes.
Quick Apps
    Allowed additional parameters to hub.alert function in QuickApp to keep backward compatibility with old code.
    Variable edit box character limit has been increased from 1024 to 2048.
Scenes
    Fixed an issue that icons other than the default ones are not displayed when selecting profiles in scenarios.
Z-Wave
    Fixed redundant stopping of Z-Wave3 engine.**
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Security:
    Angular vulnerabilities update.
    Updated Rust toolchain version.
