Hello
the above call doesn't seem to work. (maybe it was not working at all even before the update??)
I have tested it on Fibaro device that has an update available, but it doesn't do anything..
Maybe it needs some other paramater (updateVersion) or something else??
Edited by Neo Andersson
    I found out that the correct approach is to use another endpoint
    maybe @m.roszak can help a little bit here
    I have 2 questions:
    1. What is the second argument (the booelan) for?
    2. Is there some endpoint where i can get back all devices that have available update, or the only way is to loop through all devices and check their device api result?
    thanks
    for those who dont know the answer
    It is not supported anymore in HC3 series. It was used in HC2.
    On the HC3 you can still update the firmware with lua and a quickapp.
    Yes i know, and i posted right away the correct approach in my second post..but thanks
    I have 2 questions:
    thanks
    Second argument allows to use force direct communication with the devices, if those are in close proximity its speeds up a lot the process of the update.
    true -> forces direct communication.
    /monthly_2026_02/image.png.2da80ac28bb3dfefbb49aa7b2cb4d2fd.png" />
