ntg 0
I have HC2 with over 70 physical devices placed in 3 floor house and garage. Most of the devices have direct routes to HC2, apart from the ones in garage. Garage is sticked to house but it can be considered as separate building as there is 40 cm wall in between and the steel doors.
The issue is that on the wall between garage and house there is a double switch and it has no connection to the HC2 untill I place the wall plug next to it. With wall plug scenes works and I can operate with lights, but still neither double switch nor wall plug are reported by the scenes reporting routes and Z-wave range. There are also window sensors and gate switch that have no Z-wave connection too.
What should I do to make connection stable? Is the HCL as slave placed in garage best option? I'm able to place any LAN device in garage that will extend Z-wave range.
Thanks in advance.
4 answers to this question
