Problem Figaro Dimmer 2 i.c.w. Osram Halotronic transformer
Hello reader, I’m new on this platform.
In my kitchen, I'm currently using the KlikAanKlikUit AWMD-250 dimmer.
It dims two separate light rails simultaneously. Each light rail is powered by a separate dimmable OSRAM transformer (HALOTRONIC 150/230-240).
Three PHILIPS dimmable LED spotlights ranging 7.5-43 watts are connected to each light rail.
The AWMD-250 dimmer works reasonably well with the OSRAM, but it doesn't always dim as I want.
For some time now, I've had the HOMEY PRO, which works perfectly with various Fibaro switches. However, in the kitchen, I replaced the AWMD-250 dimmer with a FIBARO DIMMER 2. I don't find the connection complicated (similar to the AWMD-250), but I can't get the dimmer to work.
I connected Dimmer 2 corresponding Wiring diagram no.1: 2-wire connection/single switch.
Does anyone know:
a. How can I get Dimmer 2 to work with the OSRAM transformers?
b. Can I connect both OSRAM transformers in parallel to a single Fibaro Dimmer 2, or do I have to control each OSRAM separately with a single Dimmer 2?
Thanks in advance for your feedback and input!
Edited by Antwan
    1 hour ago, Antwan said:
    Edited by Antwan
    I would use the 3 wire connection. Also install a Fibaro Bypass.
    Have you tried playing with the parameters that control leading and trailing edge dimming?
    You should be able to use a single Fibaro device to control both transformers, but you should try 1 first and then add the second once the first is working.
    Tnx Tim, Ok I can do that (use 3-wire connection) and I'll buy a Bypass
    No, I didn't try playing with the parameters. Never done that before so I will look it up how to do that
    I'll first try to get one working. Nice to know it should be possible!
    Edited by Antwan
    Hi @Antwan,
    Note that after installation it is recommended to do calibration of the dimmer 2 to recognize load and setup parameters as best as it can.
    How to do calibration you can find here:
    I do not recommend changing most of the parameters after calibration is done except parameters 1 and 2 for minimum and maximum brightness set by calibration.
    It is also explained when bypass is needed, so I recommend first read manual and then check your installation if it is needed depending on load current.
    Hello Sankotronic, tnx for your contribution!
    I will take it into account in my approach and let you know what worked in my situation.
    Hello
    I solved the problem very easily. I think using the 3-wire connection was the breakthrough.
    Fibaro bypass is unnecessary.
    I didn't have to change parameters.
    Thank you very much guys!
    AnTwan
    Glad you got it working and thanks for reporting back!
