Hi everyone, I have several climate zones configured on my HC3L. My goal is to trigger a scene via a door sensor: when the door is opened, the climate zone should be set to the same temperature as the hallway.
However, this doesn't work—neither with LUA nor with Block Scenes. Interestingly, if I don't set it to 'Manual' but instead use 'Back to Schedule', the climate zone reacts immediately.
Has anyone encountered this problem? I’ve found a workaround using Profiles for now, which works, but I would much prefer to control the climate zones directly.
Thanks in advance, Wolle
I use the following LUA function to adjust a heating zone:
For me this works as expected. Maybe you can change and use it for your purpose.
    Thank You
    I but it in a LUA like this
    If I understand correctly, this should work.
    Unfortunately, neither setting nor resetting works here.
    Or do I need to integrate the function somewhere else?
    Thank You
    Hi @Wolle_79,
    Function provided by @Alex de Bruin is for quick app, not for the scene. You need to remove "QuickApp:" part from the name of the function and it might work.
    @Sankotronic Thank you,
    that was the error!
    Can i set the Function pubplic vor all scene?
    Wolle
    I add a copy funcction from Climazone to climazone
    If Door Open set Livingroom to the same like kitchen.
    function set_zone(id,T,H,idz)  -- Adjust heating zone id to temperature T for H hours
       local path = string.format("/panels/climate/%i",id)
       local hzone = api.get(path)
       local curT  = hzone.properties.currentTemperatureHeating
      if idz < 1 then
       --if T ~= curT then -- adjust schedule
          if H > 0 then
             local curH = tonumber(os.date("%H"))
             if curH + H > 24 then H = 24 - curH end
             H = os.time() + ( H * 3600 )
             hzone.properties.handSetPointHeating = T
          else -- H <= 0, back to scheduled mode
             hzone.mode = "Schedule"
          hzone.properties.handTimestamp = H
          api.put(path,hzone)
       --end
      else
        hub.climate.setClimateZoneToManualMode(idz, 'Heat',43200, curT, nil)
    set_zone(2,21,1,3)
    that was the error!
    Can i set the Function pubplic vor all scene?  It looks like there is no posipility, all whtat i found is setting global Varriables and then start a szene with the Funnction.
    Wolle
      if idz < 1 then
          if H > 0 then
          api.put(path,hzone)
       --end
      else
    set_zone(2,21,1,3)
    Based on my original function:
    Create for example a QuickApp with the function QuickApp:set_zone(id,T,H) and use the id from this QuickApp in your scene(s).
    From a scene you can use the call:  hub.call(QA_id,action_name,arguments) where QA_id is the QuickApp id and action_name the QuickApp function.
    For example:
         hub.call(QA_id,"set_zone",2,21,1) -- set heating zone 2 to 21 degrees for 1 hour
         hub.call(QA_id,"set_zone",2,0,0) -- return heating zone 2 to scheduled mode.
    How can i do this?
    do you have a link or any thing else how i can se the way to do that?
    Go to "Add device" on the devices page, select  "Other device" and then select Quick App. Add a name and type (generic ? )  and save the device.
    After that go to the edit tab of this new device and edit the device. Simply add the function to the lua main page and save the device.
    Thank You,
    it works very well.
    Perfect
